Troubleshoot SchemaMapper transformer setup
  • Nov 10, 2021 9:25 PM UTC
  • 107 views
stearnsweaver
Forum|alt.badge.img+4
I'm trying to import a text file without headers to FILEGDB while using the SchemaMapper Transformer to rename the columns. I've followed tutorials and articles but am not successful. Columns aren't being renamed and when I run the workspace no features are written.
Any tips would be greatly appreciated.
Here are screenshots of my parameters and workspace:
SchemaMapper ParametersCSV ParameterSchemaMapper Attribute MapSchemaMapper ActionsSchemaMapper Workspace
Schema Map (CSV):
SourceAttribute,DestinationAttribute
col0,TYPE
col1,STRAP
col2,SECTION
col3,TOWNSHIP
col4,RANGE
col5,MAP_ID
col6,CONF_FLG
col7,ADDR_1
col8,ADDR_2
col9,CITY
col10,STATE
col11,ZIP
col12,DOR_CD
col13,SUB
col14,DSCR
col15,PLAT_BK
col16,PLAT_PG
col17,NH_CD
col18,PCT_SOH
col19,INC_FLG
col20,BASE_YR
col21,ASD_VAL
col22,SOH_VAL
col23,BLD_VAL
col24,JST_VAL
col25,TAX_DIST
col26,TAX_DIST
col27,TAX DIST
col28,MILL_CD
col29,SQFT
col30,ACREAGE
itsmatt
Forum|alt.badge.img+48
  • Nov 11, 2021 8:33 AM UTC
Your best bet here is to actually use the AttributeManager to do this (SchemaMapper just gives headaches). There is an Import button which lets you import and rename based on a mapping like yours. Below are a few screen shots of the important settings. But you may need to play around until you get it looking right.
Important to is to make sure that you Connect the AttributeManager up to the reader before performing the import.
mark2atsafe
Forum|alt.badge.img+59
I think the thing is that the SchemaMapper doesn't show the mapped output in the list of columns. But if you query a feature and look in the feature inspection window (not the table view), you'll see that it has done the mapping correctly. All you need to do is connect it up to the output - and edit the output feature type to make sure it has the attributes you need. Alternatively, you can use a dynamic schema. I had to play about with this way too much to get it to work, but you can see me try in this video: https://www.twitch.tv/videos/1203669019
stearnsweaver
  • Nov 12, 2021 11:11 PM UTC
Thank you for the insight virtualcitymatt. I am trying the Attribute Manager option and will update as soon as I can get back to it.
