Transforming donut polygon to GML
  • Nov 6, 2017 3:59 PM UTC
  • 85 views
How do I transform donut polygons with a variable amount of holes from ESRI database to GML?
So far I have only succeeded in transforming one hole per polygon. Below is the code inside my XMLTemplater transformer.
<hy-p:geometry>
<gml:Polygon gml:id="id{fme:get-attribute("OBJECTID")}">
<gml:exterior>
<gml:LinearRing>
<gml:coordinates>{fme:get-attribute("_coord_outer")}</gml:coordinates>
</gml:LinearRing>
</gml:exterior>
<gml:interior>
<gml:LinearRing>
<gml:coordinates>{fme:get-attribute("_coord_hole")}</gml:coordinates>
</gml:LinearRing>
</gml:interior>
</gml:Polygon>
</hy-p:geometry>
Kind regards
Kristina Danielsson
erik_jan
Forum|alt.badge.img+26
  • Nov 6, 2017 4:01 PM UTC
Use the GeometryExtractor to create an attribute for the GML definition and insert that in the XMLTemplater.
  • Nov 9, 2017 3:44 PM UTC
Thanks for the tip erik_jan, it works perfectly in the FME-inspector.
However when I read the GML-file with QGIS my polygons turn out all twisted and mirrored?
FME-Inspector
QGIS
//Kristina
erik_jan
  • Nov 9, 2017 4:05 PM UTC
FME-Inspector
QGIS
//Kristina
Not sure. I do not use QGis.
Could it be the version of GML.
The GeometryExtractor has a number of GML versions you can choose.
You might want to try the different options.
  • Nov 13, 2017 3:51 PM UTC
FME-Inspector
QGIS
//Kristina
Thankyou again,
I examined the different versions of GML which led me to realize that I had two swap X,Y with the CoordinateSwapper before extracting the geometry.
//Kristina
