Transform multiple files in multiple folders and create that folders at the same time.
  • Jun 15, 2021 8:40 AM UTC
  • 289 views
Hi
I want to apply a transformation to all the files contained in the root folder "Vuelo84" (see attached image ). Those files are in their subfolders. I know how to load all of them in the reader, but I would like that the transformed files would be located in their own new subfolders, created by the FME itself at the same processing time. Is it possible? Thanks!
Best answer by itsmatt
You will need to have a TopLevelInputFolder Parameter and an OutputFolder parameter.
The StringReplacer should work on the fme_dataset attribute and replace the TopLevelInputFolder with the OutputFolder. use the fme_dataset attribute as the path to the output. (you may also need to change the extension if your changing formats).
If using a feature writer this should work pretty well
itsmatt
Forum|alt.badge.img+48
  • Jun 15, 2021 10:52 AM UTC
My prefered method is by building the output file path as an attribute. You can expose an fme attribute called 'fme_dataset'. This will contain the full path to the input file. You can use a StringReplacer to replace the input path to the output path
So if your input files were:
C:\\topfolderinputpath\\input1\\files.ext
C:\\topfolderinputpath\\input2\\files.ext
C:\\topfolderinputpath\\input3\\files.ext
C:\\topfolderinputpath\\input4\\files.ext
You could replace "C:\\topfolderinputpath" with "C:\\topfolderouputpath", you would then have:
C:\\topfolderoutputpath\\input1\\files.ext
C:\\topfolderoutputpath\\input2\\files.ext
C:\\topfolderoutputpath\\input3\\files.ext
C:\\topfolderoutputpath\\input4\\files.ext
This attribute can then be used in a FeatureWriter as the output file location.
The alternative is to use the fanout option in a normal writer. It doesn't preserve the input structure and you again need some way to build the folder structure as attributes
Here is some info on using fanouts: https://community.safe.com/s/article/fanout-1#:~:text=A%20fanout%20is%20a%20way,type%20fanout%20and%20dataset%20fanout.
  • Jun 15, 2021 11:23 AM UTC
Hi! Thanks for your answer. I think your method is ok when your structure is not large, but in my case I have 1098 folders within the root folder, each one of them with three or four subfolders. Is there any expression to put in the string replacer, so it will create the output path automatically? In the other hand, I can't see in the writer how I can select the new attribute as output location...
itsmatt
  • Jun 15, 2021 12:16 PM UTC
