Tiling space delimited XYZ Files
  • Nov 22, 2017 4:02 PM UTC
  • 91 views
I have a number of space delimited XYZ files (DTM data) and need to merge them and then split them into 1km x 1km tiles. The final dataset needs to be an .xml file that Civils 3D can use and produce a surface out of it.
I've used the tiler transformer but i'm running into errors during/after the tiler process
Any thoughts? Am i missing something in the process?
jdh
Forum|alt.badge.img+41
  • Nov 22, 2017 5:01 PM UTC
It would be helpful if you said what exact error you encountered is.
fmelizard
Forum|alt.badge.img+22
  • Nov 25, 2017 12:38 AM UTC
Hi @jb_gisb1 If you suspect a problem with FME then please send us some sample data and your workspace via www.safe.com/support Thanks!
