The wrong log file gets updated
  • Feb 27, 2020 8:52 AM UTC
  • 6 replies
  • 77 views
fmenco
I run a workbench automatically through task scheduler. I've recently renamed this workbench (let's call the old one workbenchA, and the new on workbenchB). I have also updated the task. However, whenever this workbench runs through the taskscheduler, the logfile that gets created or updated is the one referring to the old name (so workbenchA.log). It does run workbenchB and says it as well in the workbenchA.log, but just sticks to the old filename when it comes to logging.
I've already emptied my user temp folder. I've also now renamed workbenchA. But it still does it. It's like something is stuck in cache memory somewhere, but I don't know where to look. Also, when I manually start the workbenchB it does create a logfile with the correct name.
I Have FME Desktop version 2019.
Forum|alt.badge.img+54
  • Feb 27, 2020 9:00 AM UTC
Is there a logfile set in the workspace parameters?
fmenco
  • Feb 27, 2020 9:59 AM UTC
I just checked and no there's no logfile set in the workspace parameters.
itsmatt
Forum|alt.badge.img+48
  • Feb 27, 2020 3:11 PM UTC
I would try clearing the task from the scheduler and then resetting it up again (if you haven't tried that yet)
tibor
  • Feb 27, 2020 9:25 PM UTC
The problem lies in the renaming issue.
FME Stores the Workspace name when it's saves the workspace. That name is by default used for the logfile name.
Try SaveAs instead of renaming the FMW file.
fmenco
  • Feb 28, 2020 8:33 AM UTC
Yes, this did the trick! Thank you!
fmenco
  • Feb 28, 2020 8:34 AM UTC
Yes, I tried this. The issue was the renaming itself (see answer above) :-)… Thank you
