The Number of Quotation Marks in Command Line on Translation Log
Hello,
From this Q&A;: command line fails
Workbench generates a command line when starting the translation and prints it in the Translation Log. It's helpful, but the number of quotation marks surrounding a parameter value seems be too much when the value consists of multiple file paths.
For example, a workspace generated this command line,
"C:\Program Files\FME 2017.1\fme.exe" C:\FME\tmp\textline2none.fmw
      --SourceDataset_TEXTLINE """"""C:\FME\tmp\data_0.txt"" ""C:\FME\tmp\data_1.txt""""""
but I think this is correct, if you run the workspace from the command prompt.
      --SourceDataset_TEXTLINE """""C:\FME\tmp\data_0.txt"" ""C:\FME\tmp\data_1.txt"""""
How do you think about this?
Best answer by trentatsafe
Hi @takashi,
The issue here does appear to be related to a known issue. I've created a case from your repro (and attached you to it) and attached it to the PR. I will notify you of any changes. Thank you very much for the repro and the suggested workaround. I was able to mimic your results, and as such your workaround appears to be the best way forward until a fix is implemented! I have commented as such on the public question located here: https://knowledge.safe.com/questions/46102/command-line-fails-1.html notifying them, that your suggestion is the best way forward. Thank you very much.
Kind regards.
fmelizard
Forum|alt.badge.img+18
  • June 22, 2017
Hi @takashi The extra quotes do appear to be excessive but does it work? There have been several problem reports about this in past years and I think that all have been resolved. I suspect that fewer quotes won't work in all cases.
  • June 23, 2017
Hi @DanAtSafe, in my quick test, the command line having extra quotes fails to run the translation. Could you please check the attached demo? command-line-test.zip
Fail (generated by Workbench, having extra quotes):command-line-test-fail
"C:\Program Files\FME 2017.0\fme.exe" C:\command-line-test\textline2none.fmw --SourceDataset_TEXTLINE """"""C:\command-line-test\data-1.txt"" ""C:\command-line-test\data-2.txt""""""
Success (removed extra quotes):command-line-test-success
"C:\Program Files\FME 2017.0\fme.exe" C:\command-line-test\textline2none.fmw --SourceDataset_TEXTLINE """""C:\command-line-test\data-1.txt"" ""C:\command-line-test\data-2.txt"""""
trentatsafe
  • June 23, 2017
Hi @takashi,
Kind regards.
