The error number from ArcObjects is: '-2147220936'.
  • March 17, 2020
  • 522 views
nag
Hello Team,
I am loading data from .JXL to SDE, While loading data i got following error, Could somebody help me out with some resolution for the issue.
|ERROR |An error occurred while attempting to add a shape to a feature buffer. The error number from ArcObjects is: '-2147220936'. The error message from ArcObjects is: {The coordinates or measures are out of bounds.}
Thanks...
  • March 17, 2020
Based on the error message it sounds like the source coordinate values are outside the valid ranges defined in the coordinate system set on the target feature class.
Maybe you need to reproject the coordinates before writing them.
