The equivalent tool to AutoCAD’s “explode” in FME,
  • December 18, 2014
  • 8 replies
  • 440 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out which tool is equivalent to Explode tool of AutoCAD in the FME.
Thank you
Best
Jamal
Best answer by samisnunu
yes it should be..
ok sorry try setting the  (Maximum Verticies :2 )  for the chopper..
samisnunu
Forum|alt.badge.img+15
  • December 18, 2014
Jamal - Use the Deaggregator transformer.
jamal
  • December 18, 2014
Thank you Sami for the answer,
If the square is exploded in the AutoCAD then 4 lines are generated.
Applying the deaggregator to the same square fails to introduce 4 lines.
What might be the issue here?
samisnunu
  • December 18, 2014
Then try using Deaggregator, GeometryCoercer and then a Chopper..
The trick here is to determine the chopper's settings for the interval to explode (Split) for your case..
  Mode: By Vertex
  Maximum Verticies :3
jamal
  • December 18, 2014
The workbench below fails to explode the square and then to generate 4 lines.
What I wanted is a tool that can explode objects at each vertex which is the default behavior in the “explode” tool of AutoCAD.
Is this still possible in the FME?
samisnunu
  • December 18, 2014
yes it should be..
jamal
  • December 19, 2014
Perfect Sami. It works fine now.
Then what is the advantage of the “deaggregator” in this case?
fmelizard
Forum|alt.badge.img+22
  • December 19, 2014
none and also the GeometryCoercer serve no purpose in this case.
jamal
  • December 19, 2014
Thanks ETLS. This is what I guess. Then Chopper is the equivalent tool for Explode
Best
Jamal
