Tester with 'Begins with' conditions on Oracle table works in FME Desktop, but fails without error notice.
  • Aug 9, 2022 6:39 AM UTC
  • 39 views
pimververgmail
An Oracle table with 16339 features is called in a workflow. After that a tester selects items with conditions: CODE begins with RK or CODE begins with PK. All but 4 items are selected. The workflow works without problems in FME Desktop, but fails on FME Server. As an alternative I put an SQL query in the tabel reader: CODE LIKE 'RK%' OR CODE LIKE 'PK%'. To my surprise it - again - works in FME Desktop but fails on the server. So it seems the problem lies in the Oracle database table. Any thoughts?
@pimververgmail​ That is pretty odd.
  • are your FME Desktop and FME Server versions the same?
  • are you sure your FME Server is pointing to the same Oracle database?
  • is it possible yo should be checking for lowercase 'rk' or 'pk'
