Tester transformer does not produce the desired result
  • Jan 21, 2020 9:54 PM UTC
  • 67 views
Hi there,
I am applying a filter on record using tester transformer. My test clauses contains multiple And/OR conditions. I have attached screenshot of the test clauses. The problem is tester does not filter the record the way I wrote the condition. For example, I dont want to include the record in which CAUSE attribute has value 2A or 2B. However, in the tester passed category contains the record that has CAUSE value of 2A or 2B. Similarly, I do want to include the record in which the description attribute contains the value "BLOWN LV FUSE". However, passed category does contain those records. Could anyone guide me where am I making the mistake?
erik_jan
Forum|alt.badge.img+26
  • Jan 21, 2020 10:05 PM UTC
The part that has CAUSE != 2A OR CAUSE != 2B is always true.
I think that needs to be CAUSE != 2A AND CAUSE != 2B
Same issue with the DESCRIPTION (should be AND).
The Tester has an option to do: AND NOT DESCRIPTION Contains <value>.
Hope this helps
Hope this helps
Thanks for the clarification. Just a follow-up question. Can we enter all values of description in a single contain operator? If yes, then how do we separate the values (comma, or double quote)?
erik_jan
  • Jan 22, 2020 2:28 PM UTC
You can use the IN operator to do so.
Have a look at the Help for the Tester here
