Tester query
  • February 28, 2013
  • 12 replies
  • 143 views
Hi (again),
I am running a workbench with a simple Tester that isn't giving the desired results.  I have a published parameter set to a value "00MF" and the same value exisits 128 out of 500 times in a .csv file (no other columns).  I have set up a test that compares these two attributes called EQ_Query_LA and Origin_LA but I get no matches.  I've attached a screenshot below.  I'm sure it's really simple, but I  can't put my finger on it!
I've tried it with values that are only numbers or only text and changing the mode.
Grateful for any answers!
  • February 28, 2013
Link to image:
http://dl.dropbox.com/u/7141908/TesterWorkspace.png
  • February 28, 2013
Some things to try:
  • Set the test clause mode to "String"
  • Try inserting an AttributeTrimmer first
  • Make sure that the values to compare have the same case
  • February 28, 2013
Hi Dave,
Thanks for the reply.
I tried all of the above, all 500 csv entries and the parameter fail, i.e. 501 fails.
  • Tester set to string
  • Inserted 2 x CaseChanger (set to Uppercase)
  • Inserted 2 x AttributeTrimmer (Trim type:Both & Trim Characters: blank)
  • February 28, 2013
For me, the next logical step would be to insert inspection points just before the Tester to make a visual check of the parameter values entering the transformer.
David
  • February 28, 2013
OK, I've given that a spin and I get the results below (not resolved).  I'm completely stumped!
First inspection point:
http://dl.dropbox.com/u/7141908/TesterWorkspaceIP1.png
Second inspection point:
http://dl.dropbox.com/u/7141908/TesterWorkspaceIP2.png
Tester Parameters
http://dl.dropbox.com/u/7141908/TesterWorkspaceTesterParameters.png
(p.s. I just noticed the _ in front of one of the attributes which I've removed, it hasn't been causing the problem.
Thanks.
  • February 28, 2013
Try using the operator "LIKE" and see what happens.
David
  • February 28, 2013
Thanks for the reply, I did try a few different operands, have gone through them again:
  • Like: 501 fails
  • Contains 500 pass, 1 fail
  • Begins with: 500 pass, 1 fail
  • Ends with: 500 pass, 1 fail
  • In: 501 fails
Still no joy unfortunately.
dustin
Forum|alt.badge.img+36
  • February 28, 2013
Try using the TestFilter instead of the Tester.
  • February 28, 2013
I tried to use a published user parameter in a Tester transformer in FME2013. It worked as expected. FME uses the following syntax to refer to the value of a parameter:
  $(ParameterName)
Try the following text in the "Test Clauses"."Left Value" (of the tester parameter disalog):
    $(Param_EQ_Query_LA)
Good Luck!
  • February 28, 2013
I have tried to use a published user parameter in the tester transformer in FME2013. It worked as expected. The syntax used: $(ParameterName)
So you may enter the following text in Tester parameters dialog:
Good Luck!
  • March 4, 2013
Thanks byjukp!!  It now works!  It looks like the Tester doesn't work unless the Attribute is explicity exposed as a Parameter as per your post.  I'll feed it back to Safe.  Got there in the end!
Thanks again everyone.
gio
Forum|alt.badge.img+15
  • September 11, 2013
tho an old issue, i find it amazing.
As, at leat in 2012 u can simply choose the parameter in the dropdownlist.
U dont even need to fetch it.
