Test the type of attribute and test attribute value
  • May 9, 2017
  • 5 replies
  • 506 views
mgeomaticien
Hi all,
I'm new on using FME, I have a question that troubles me
At first I would like to check the type of an attribute (text, number, ...). Then I would test if the values of an attribute belong to a list of attributes already predefined.
An idea please ?
thank you in advance,
jdh
Forum|alt.badge.img+41
  • May 9, 2017
itay
Forum|alt.badge.img+19
  • May 9, 2017
Hi @mgeomaticien,
To test the attribute type use the schema reader and for the value a attribute value mapper transformer can be used. Have a look at the transformers documentation on how the set invalid values so that you can afterwards easily test them.
mgeomaticien
  • May 11, 2017
Hi @jdh and @itay
Thank you for yours answers.
Please I have another question. I want to Check the presence of one or more layers (which I already know the names) and in each of the layers verifies the existence of one or more attributes (already known) when reading the data source.
I would also like to control the object type of each layer (polygon, point, line, text ...)
My data source is DWG file
Thank you in advance
itay
  • May 11, 2017
You can use the fme_geometry attribute or GeometryFilter transformer to do that. JUst rememeber to expose the attribute.
mgeomaticien
  • May 11, 2017
Thank you. But before that I would like to check the existence of layers and attributes
