Table View: Failed to read rows due to 'No query Unable to fetch row'
  • Feb 28, 2023 6:57 PM UTC
  • 162 views
townest
Forum|alt.badge.img+4
I recently received the subject error. The error occurs when inspecting any downstream table of an AutoCAD dwg reader. The workspace appears to run successfully, then while scrolling down the transformer inspection table (in visual preview), the inspector suddenly throws an error and breaks out of the visual inspector table into the translation log showing the subject error. Clicking back on the table, and no records are shown past 100 (there are actually 1000s of records).
Any ideas about what is going on?
Thank you,
Tyler
FME Workbench 2022.1
evieatsafe
Forum|alt.badge.img+28
  • Mar 4, 2023 12:50 AM UTC
Hi @townest​ sorry that you have experienced issues with FME! I believe we need some additional information so we can investigate.
  • Could you provide a log file with FME_DEBUG logging enabled?
  • Could you also try writing to FFS instead of viewing the feature cache in the visual preview, does the workspace succeed? Can the FFS be opened in Data Inspector with all of your features present in table view?
  • And, if we can write to FFS, what does the temporary SQLite file contain? Are all the rows present?
Look forward to hearing from you.
