Hi. I have a change detector. If the folder have some change i have a system Caller to open a txt files. But the system caller open 13 times. I want the system caller opening only one time. Can you help me. Thank
System caller configuration
Best answer by david_r
Try inserting a Sampler set to only let the first feature pass through.
