System caller configuration
hugues
Hi. I have a change detector. If the folder have some change i have a system Caller to open a txt files. But the system caller open 13 times. I want the system caller opening only one time. Can you help me. Thanksystem_caller
Best answer by david_r
Try inserting a Sampler set to only let the first feature pass through.
  • May 15, 2023
hugues
  • May 15, 2023
Thank you very much !
