Syntax to extract children into attributes with XMLFragmenter
  • Mar 6, 2023 6:37 PM UTC
  • 146 views
aaron
Forum|alt.badge.img+12
I am using an HTTPCaller to return some XML which I then want to turn into attributes. I can extract the Project fragment below using the XMLFragmenter (with Projects/Project in the Elements to Match parameter) but I haven't figured out how to directly extract the children into fragments or directly into attributes. Using Projects/Project/* doesn't work. For instance, I want to extract ProjectNumber and Status more directly into attributes. So far my solution has been to use a StringSearcher and SubstringExtractor to get each attribute. That's a tedious way to do it. Any advice on a better way?
<?xml version="1.0" encoding="UTF-16"?><Project ProjectId="508DKDS6B2KA" ProgramId="YAK0C5V4UNVH" ProjectNumber="EST-00001" Status="Cancelled/Archived" StatusTimestamp="2021-04-01T12:23:55-06:00" LastChangeTimestamp="2021-06-29T14:15:01-06:00" ></Project>
Best answer by aaron
Try something like this:
imageResult:
Thanks @david_r​ , worked perfectly.
  • Mar 7, 2023 8:15 AM UTC
imageResult:
aaron
  • Mar 7, 2023 4:42 PM UTC
imageResult:
