Syntax FindRegEX
  • August 1, 2017
  • 5 replies
  • 148 views
cprhamel
Hello everyone
I try to extracted from a character string the end of a block separated by a /
for example _temp / resources / temp / 2017072_email / 12-680-RER @FindRegEx (@Value (_temp), /, - 1 ,,) I can not find the right syntax to look for the character / starting from the right And then cut the block with a @right at the position of the / thank you for your comeback
Best answer by ebygomm
Try with regex [^\\/]*$ so @FindRegEx(@Value(filename),[^\\/]*$)
Using the regex in a stringsearcher is an easier way to return the value than using findregex and then cutting the string though
danilo_fme
Forum|alt.badge.img+56
  • August 1, 2017
Hi @cprhamel,
In your case i used the transformer AttributeSplitter to split in " / ". After a list attribute is created:
You can get the last list attribute: _list{4}.
Thanks
danilo_fme
  • August 1, 2017
Hi @cprhamel,
Thanks
Continue with transformer ListElementCounter to get the number of lists created.
With ExpessionEvaluator @value(_element_count) - 1 ) get dynamic mode the last List number.
The AttributeManager it mapped the the value to new Attribute Last_element = @Value(_list{@Value(_result)}).
Attached the template file.
Thanks,
Danilo - workspace-list.fmwt
Forum|alt.badge.img+52
  • August 1, 2017
  • August 1, 2017
If your goal is to extract the last part (i.e. "12-680-RER") from the slash separated string, you can use the @ReplaceRegEx with this setting.
@ReplaceRegEx(@Value(_temp),.+/\s*(.+?)$,\1)
cprhamel
  • August 2, 2017
Thank you for your answers
They work well
I will use that egomm to stay in my usual schema
Can you explain to me the set of code used For later use Thank you all for your cooperation
