Surface output to LandXML
  • November 13, 2012
  • 79 views
svantepanter
Hi!
I find LandXML very useful for getting data out from AutoCAD Civil 3D. But I have never succeeded to WRITE a LandXML-file from FME. Does anyone know how to setup a workflow for doing that?
Typically I´m creating a surface using the SurfaceModeler, and I want the Triangles or the TIN-surface to be written to the LandXML-file.
Best regards,
Svante
sigtill
Forum|alt.badge.img+24
  • October 22, 2019
Hi @svantepanter - You can look at this to create the needed featuretypes https://knowledge.safe.com/articles/1203/creating-landxml-files.html
Also for Civil3D you need some additional featuretypes (CoordinateSystem). Look at the header of a Landxml that CAN be opened in Civil 3D and try to replicate that by adding more featuretypes with the needed attributes.
