Subtract dates
  • September 27, 2013
  • 543 views
I have 2 dates in the format 20130831000000 (DATE) and 20130905000000.000000 (TIMESTAMP).
How can i subtract them in FME in a way that the format of answer is in days (eg. 5) ?
I used dateformatter in FME to convert them to 2013/08/31 but the TIMESTAMP-DATE doesn't react properly.
Greetings, Pieter
  • September 28, 2013
Hi Pieter,
As far as I know, FME currently doesn't support simple calculating function for date / datetime values. You will have to append the functionality with creating a custom transformer or defining a python script. Or, you can also consider to use the DateDifferenceCalculator custom transformer from FME Store.
http://fmestore.safe.com/transformers/DateDifferenceCalculator.htm
Takashi
fmelizard
Forum|alt.badge.img+22
  • September 29, 2013
Currently the store transformer is the way to go to do calculations on dates.
  • September 30, 2013
here is a solution pased on a PythonCaller:
import fmeobjects from datetime import date from time import strptime   def FeatureProcessor(feature):     # Get attributes     my_date = feature.getAttribute("my_date")     my_timestamp = feature.getAttribute("my_timestamp")          # Parse string attributes to time objects     t1 = strptime(my_date, "%Y%m%d%H%M%S")     t2 = strptime(my_timestamp, "%Y%m%d%H%M%S.000000")       # Convert to date objects     d1 = date(t1.tm_year, t1.tm_mon, t1.tm_mday)     d2 = date(t2.tm_year, t2.tm_mon, t2.tm_mday)          # Number of days between the two dates     day_delta = abs((d1 - d2).days)          # Set result attribute "delta"     feature.setAttribute("delta", day_delta) -----
It requires two attributes "my_date" and "my_timestamp" and will return a new attribute "delta" which will correspond to the number of days between the two input dates.
David
  • October 1, 2013
Thanks for your reply and support, it works now !
I first upgraded from FME2012 to FME2013
There i used de dateconverter to convert de date-field to timestamp-format %Y%m%d%H%M%S.000000'
With de DateDifferenceCalculator i managed to calculate the difference in days.
Pieter
