Styling 3D shapes in the data inspector
  • Feb 12, 2020 3:53 PM UTC
  • 86 views
jw4554
Forum|alt.badge.img+4
Is it possible to colour 3D shapes in the data inspector based on an attribute? I have 3D features that stack on top of each other and seeing all shapes in one shade of grey makes them hard to tell apart and check.
sigtill
Forum|alt.badge.img+25
  • Feb 12, 2020 4:11 PM UTC
Hi! would suggest doing that in FME Workbench using a FeatureColorSetter (random based on an attribute) and then use the Inspector and "fanout" on that attribute to be able to turn them off/on in the data inspector
jw4554
  • Feb 13, 2020 9:16 AM UTC
Great, thank you @sigtill. I still seem to be missing a step though - my 3D shapes are still a lovely shade of grey! I have attached a snippet of my workspace if you are able to spot anything in it? example.fmw
sigtill
  • Feb 13, 2020 10:45 AM UTC
Seems there is an error on the uploaded file:
If it is a more complex 3D-object (not a point,line or area) you need to have a look at this tutorial to add an Appearance:
https://knowledge.safe.com/articles/1120/add-appearances-to-a-3d-city-model-geotiff-dwg-las.html
jw4554
  • Feb 17, 2020 10:00 AM UTC
Perfect! Thank you for your help.
