Stringreplacer, regexp with captures. Test conditional using capture(s) .....not possible? (image) the righthand side works. I can use the captures. In the lefthandside it seems not able to catch the capture(?) Is this a limitation? GREE
gio
Forum|alt.badge.img+15
afbeelding
  • August 25, 2022
@gio​ Perhaps a little more explanation of the problem and maybe an example of the data and workspace would help someone point you in the right direction
gio
  • August 26, 2022
Hi MArkatsafe.
Transformer: Stringreplacer with regexp replace.
For instance fegexp : bla(.+)bla has 1 capture.
In the condition side i have this test
\\1=@Value(_attr_name).
The "\\1" is a reference to the first capture in he regexp.
It does not process.
In the text to replace side the references to the captures do.
So, is it a limitation?
IS conditional regexp replacement thereby flawed?
Greets.
I dont think a workspace is required. It is just 1 transformer that's the issue.
(course i tackled it differently by now. Maybe ill try it in latest version.).
