String Replacer with number, strings and decimals
  • November 28, 2017
  • 181 views
Hi all,
I was unable to find an answer I needed so I thought I would post.
I have been using the StringReplacer and am trying to learn the regex commands to no avail.
I have a column with values that are mostly numeric, some alphabetical, some blank and some number with decimals. I would like to ensure that every number that does not have a decimal gets a decimal added to it.
Example of value range:
000625.224
512566254
662512566
751256.335
TLL
003640.123
CODD
My ask is how can I use the StringReplace (or any other transformer) to take the numeric values here. And insert a period in between the 6th and 7th characters. Leaving 6 before the decimal and 3 after.
To note. Every numeric value that has a decimal is 10 characters. 6 before the decimal, one decimal and 3 following. Every numeric value that does not have a decimal is 9 characters. I want to keep all Alphabetical and Null values untouched.
Thank you for your help!
Best answer by jdh
I would use the StringReplacer in Regex mode with the Text to Replace set to ^([0-9]{6})([0-9]{3})$ and the Replacement Text as \\1.\\2.
jdh
Forum|alt.badge.img+28
  • November 28, 2017
  • November 28, 2017
Okay! yes that seems to have done the trick for that exact question. Thank you for your quick response.
jdh
  • November 28, 2017
To explain the regex, the () create parts that you can reference in the replacement text. \\0 is the entire matched text, \\1 is everything inside the first set of parenthesis, \\2 the second etc.
[] is match any one of the characters inside the brackets, in this case the numeric range 0-9
{n} is match the preceding character (in this case any of 0-9) exactly n times
^is the start of the line
$ is the end of the line
these make sure we don't have something like ABC123456789
  • November 28, 2017
awesome! that explanation is extremely helpful
