String Replacer doesn't catch Unicode Character
  • Mar 29, 2018 9:51 PM UTC
  • 111 views
denizturan1985
Participant
Hello all,
I have a problem with catching Turkish Unicode characters in StringReplacer and StringSearcher transformers. "\\w" function doesn't catch " Ç ç ? ? ? ? Ö ö ? ? Ü ü" letters. It works when I put these letters in the search bar. Also, I checked the same letters on www.regexpal.com and it didn't work too.
Is there any solution to catch these letters with "\\w"? Otherwise, I need to change these letters with other special characters which don't exist in Turkish Alphabet at the beginning and the end of the Workspace.
Thanks
Deniz
bruceharold
Forum|alt.badge.img+20
  • Mar 29, 2018 10:06 PM UTC
Try \\X
From a quick read of PERL unicode support
If you can resort to Python it gets a bunch easier with the -U flag.
denizturan1985
Participant
Hello @bruceharold
Thank you for your answer. \\X selects everything including whitespace. My strings include letters, whitespaces, dots and, numbers. I am going to select everything and, exclude numbers whitespaces and, dots. Also, thank you for the Python advice. All the doors open to Python, I should start to learn.
Thank you
Deniz
  • Apr 3, 2018 7:29 AM UTC
The "\w" metacharacter (usually) only matches the set [a-z, A-Z, 0-9, _], that's why your special characters aren't included.
You best bet is to specify your own set, e.g.
[\wç?ü...etc...]
