string concatenation issue
  • May 1, 2015 7:27 AM UTC
  • 5 replies
  • 138 views
I want to create a paragraph number like "1.2" from a literal "1." and the output attribute from a Counter using an expression in AttributeCreator.
Simple eh?
When the Counter is 2 I get the correct string "1.2" but when the Counter is 1 the output is "1.1000000000000001" as if it's a floating point operation with a rounding error.
I've tried
           @Trim(1.)@Evaluate(@int(@Value(street_count)))
to try and force string behaviour with no effect and I've tried using StringConcatenator instead of AttributeCreator in case that made a difference (doesn't).
Any ideas?
  • May 1, 2015 9:25 AM UTC
It might be a side-effect caused by change about handling of internal data types in FME 2015.
I don't know whether it's intentional.
Anyway, workarounds.
a. Concatenate twice.
(1) _result = .@Value(street_count)
(2) _result = 1@Value(_result)
b. Use a suitable character other than dot (e.g. hyphen) as the delimiter when concatenating, and replace the character with a dot later, by a StringReplacer.
c. Use a TclCaller with this expression.
return [format {1.%d} [FME_GetAttribute "street_count"]]
and so on.
Takashi
  • May 1, 2015 9:47 AM UTC
This Tcl expression is simpler than the previous one.
gio
Forum|alt.badge.img+15
  • May 1, 2015 1:31 PM UTC
In 2015 version you can't get past the forced evaluation. In 2014 you could remove the @Evaluate or the "=" sign. But in 2015 that is not possible. It is some symbol now...
i filed an issue on that, because it blocks the use of a lot of tcl in the attributecreator/tester etc..
gio
  • May 1, 2015 1:34 PM UTC
btw....the concatenator transformer has no issue with that, afaik.
But we passed on fme2015 and await the fixes we hope they will make in the next patch.
  • May 6, 2015 6:41 AM UTC
Takashi,
Concatenating twice gives me the same result as before, but concatenating with hyphen and then substituting a dot does the trick, thanks.
And thanks to everyone who replied.
