String Compare for TestFilter
  • November 20, 2013
  • 5 replies
  • 180 views
Excuse my knowlege of TCL (it is very rusty).
I have a stream of featues (fme_line), with the attribute:
Attribute(encoded: utf-8) : `type' has value `Ferry Route'
or
Attribute(encoded: utf-8) : `type' has value `Major Highway'
I am trying to use the TestFilter to find the ferrys.
I have the following StringFinder call, but it always returns -1:
@FindString(@Value(type) , "ferry", 0, FALSE)
also I have tried something simpler
@Value(type) = "Ferry Route"
But that also is always failing.
And this also does not work:
@Value(type) CONTAINS "Ferry"
any ideas?
Best answer by dr_ysg
I'm sorry
It really should be
@Value(type) CONTAINS Ferry (with no quotes).
  • November 21, 2013
The FindString function seems not to trim white spaces in the parameter string. Try these expressions: @FindString(@Value(type),"ferry", 0, FALSE) or @FindString(@Value(type),ferry, 0, FALSE)    But, I believe these expressions would work. Sounds strange... @Value(type) = "Ferry Route" @Value(type) CONTAINS "Ferry"
Takashi
  • November 21, 2013
But all of these varients, I listed in my original message as NOT WORKING. I just retried them exactly as you specifed (in an expression evaluator,
the FindString() is returning -1 always
and the others are false.
And the other two crash the expression evaluator
RoadMaker_ExpressionEvaluator: Failed to evaluate TCL expression: Major Highway CONTAINS "Ferry"
RoadMaker_ExpressionEvaluator: TCL Error Message: invalid bareword "Major"
in expression "Major Highway CONTAINS "Fer...";
should be "$Major" or "{Major}" or "Major(...)" or ...
Which seems to point a TCL syntax issues of quoatation,
  • November 22, 2013
I reproduced the error message with the ExpressionEvaluator. Did you perhaps type this expression directly in the editor of ExpressionEvaluator? @Value(type) CONTAINS "Ferry"   If so, it will be transformed like this, when receiving a feature. Major Highway CONTAINS "Ferry" Naturally it is not a valid expression to be interpreted by the Tcl interpreter.   If you want to use the ExpressionEvaluator, try this expression. @FindString(@Value(type),ferry,0,FALSE)   Or, consider using the Tester transformer with this setting. Left Value  |  Operator  |  Right Value type  |  Contains  |  Ferry * type is the attribute name, Ferry is a constant value.
  • November 22, 2013
@Value(type) CONTAINS "Ferry" was the only magic verison that works (for the TestFilter Transform). But it does work, so thank you.
  • November 22, 2013
I'm sorry
It really should be
