I have 2 transformers (A and B) they have to provide a Sorter with inputs. If there isn’t any output from A, then this workflow C has to stop, but not the entire workspace. If there is output from both A and B, it has to continue. If there is only output from A and not B, it has to contiunue.
Is it possible?
Best answer by virtualcitymatt
My favorite to use the the FeatureFlowValve custom transformer. Inside it’s essentially just a FeatureMerger with 1==1 but I like it because I can choose whether it opens or closes what does through the Input
A+B == A+B
In this case A is the ValueControl and features will only go through in the case there is a feature coming out of ‘A’
How about this? put a 1 in both the key fields for the attribute merger. depending on the schema you may need to remove extra attributes from the merge fields so it only matches the requestors schema.
A+B == A+B
Thank you very much for all the answers. The last one, where “FeatureFlowValve” was used, is perfect for the purpose. However, the other methods also worked :)
I thought it was time that we had a better solution for this type of scenario, so I created the DataLogicController transformer and uploaded it to the FME Hub.
Basically, for this scenario, the setup would look like this:
The logic to use is called “Projection”. It’s also capable of doing AND (must have both A and B data), OR (only needs one set of data), and a host of other logical operations.
I hope you find this interesting (even if you have a solution already).
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
