SQLExecutor + Stored Procedure in MSSQL: Executed or not?
  • November 15, 2012
  • 80 views
sigtill
Forum|alt.badge.img+25
When using the SQLExecutor with a Normal SQL like:
SELECT *
FROM mytable
WHERE id LIKE 11111
It will return an attribute "_matched_records" with the number of records matched in from TRIGGER port.
However when using an EXEC-statement this does not seem to happen. Like this:
EXEC @return_value = [dbo].[myStoredProcedure] @ID = N'@Value(IID)',
@myTableValue = N'@Value(myValue)',
So after doing this it is not possible to figure out if the EXEC have actually run and inserted the needed attribute - or if there is an error performing this request. Anyone with a good workaround OTHER than doing another SQLExecutor to try to read back the data and try to compare the features? (Many features = alot of time reading and writing)
sigtill
  • November 15, 2012
A thank you goes to Ken Bragg that helped solve this issue. The solution was to add SET NOCOUNT ON; on the StoredProcedure.
fmelizard
Forum|alt.badge.img+22
  • November 15, 2012
Although I have to admit - I stumbles upon that while doing a really complicated work-around. Luck!
