SQLExecutor - Incorrect Syntax - Trying to Disable Trigger on SQL DB
juliarozema
Forum|alt.badge.img+7
Hello,
I have a SQLExecutor connecting to my SDE on a SQL database. I am using the Microsoft SQL Server Non-Spatial Format with an embedded Connection.
My SQL Statement is:
FME_SQL_DELIMITER ;
GO
DISABLE TRIGGER gisowner.SEGME_MSLINK_COUNTER ON gisowner.[a10];
GO
I get the following errors:
Query failed, possibly due to a malformed statement.
Provider error `(-2147217900) Incorrect syntax near the keyword 'TRIGGER'.'
Failed to read features from dataset 'AHS_GIS' using the 'MSSQL_ADO' reader
trentatsafe
  • October 9, 2018
Hello @juliarozema
The cause of the error is the GO statement. The GO is not a true T-SQL statement, but is used with SQLcmd or OSQL utilities(such as SQL Server Management Studio). More information can be found here: https://docs.microsoft.com/en-us/sql/t-sql/language-elements/sql-server-utilities-statements-go?view=sql-server-2017
As such if you alter your statement to the following:
FME_SQL_DELIMITER ; DISABLE TRIGGER gisowner.SEGME_MSLINK_COUNTER ON gisowner.a10;
 I tried the above with my own syntax and it worked correctly. I hope that helps!
juliarozema
  • October 10, 2018
trentatsafe wrote:
Hello @juliarozema
Thank you so much!!
ponting13
Forum|alt.badge.img+5
  • November 30, 2023
Were you able to replace "GO" with something else to make this statement run?
