SQL To Run after Wrtite -Incorrect Syntax - Provider error `(-2147217900). Adding a named constraint primary key
  • Jun 17, 2020 3:18 PM UTC
  • 182 views
moraalejandra93
Participant
Hi guys, I'm trying to add a named constraint primary key into a large number of SQL Server tables joined in one reader with this code in the 'SQL to Run after Write' part:
FME_SQL_DELIMITER ;
ALTER TABLE @Value(fme_basename)
ADD CONSTRAINT PK_@Value(fme_basename) PRIMARY KEY (id1)
But I got this error:
Microsoft SQL Server Spatial Writer: Query failed, possibly due to a malformed statement.  Query Text `ALTER TABLE @Value(fme_basename)
ADD CONSTRAINT PK_@Value(fme_basename) PRIMARY KEY (Id1)'. Provider error `(-2147217900) Incorrect syntax near '@Value'.'
Does anyone know what is the error? Or how can add a Primary Key for a large number of tables joined in one reader?
Thanks a lot
erik_jan
Forum|alt.badge.img+26
  • Jun 17, 2020 3:29 PM UTC
Not sure you can use attributes in the After SQL statement.
A way to solve this is:
Use the FeatureWriter instead of the writer.
On the Summary output you have a list of feature types (tables) that are written to.
You can use that list (ListExploder) followed by a SQLExecutor to create the constraints.
Another thought:
fme_feature_type should be the fme attribute that contains the name of the table, not fme_basename.
Hope this helps.
