Hello to the community,
I successfully set up an fme flow automation with a final action to send out an smtp email via our email server. The connection to this email server with the “SMTP Account” is valid and successfully tested and mails were sent. But the “SMTP Account” is not setup to receive emails at all.
When i try to change the parameter “Email From” in the “email send” action to a different mail address than the used “SMTP Account”, our mail server denies to send out the email as a different user.
This is for security reasons.
But i want the email recipients to be able to just reply to an incoming email without changing the mail address. Further I don’t want to place a hint in every mail that it is not possible to simply reply to this mail without changing the address.
Is there another way to change the smtp header parameter “replyto” for the email send action in fme flow?
Thank you very much for any help and hints
best regards
Jürgen
