sql statement
  • September 10, 2015
  • 216 views
Hi, all:
I have a huge MS SQL Server Non-spatial database,each record has a "datetime" time stamp. Now I'm using "SQLCreator" to read the data.
In the SQL Statement, I wrote:
SELECT * FROM mytable
WHERE  ID='1007'
AND YEAR(datetime)=2015
AND MONTH(datetime)=1
But I cannot get the data and FME say: MS SQL Server Reader: Query failed, possibly due to a malformed statement. Provider error `(-2147217871) Query timeout expired'
Does anyone know the reason?
Thanks in advance,
Ariel
Best answer by fmelizard
FME will set a timeout value by default. If you are encountering this error, you set the Command Timeout to 0 so there is no timeout.
I think myself find the method, I used Command Timeout as '9999999" but after change that to 300 seconds, it works. :)
  • September 11, 2015
Hi
You might want to verify that your fields ID and DATETIME have been properly indexed, it shouldn't take many seconds to run a query like this.
David
Hi, David:
Thanks, yes they are properly indexed. I got it running now.
fmelizard
Forum|alt.badge.img+22
  • September 12, 2017
