Splitting line by angle
  • Aug 13, 2018 2:35 PM UTC
  • 6 replies
  • 296 views
Instead of splitting a line by distance or specific vertex indexes, I want to split lines whenever the angle to the next segment is not within x degrees.
Any ideas on how to accomplish this?
For now, I've calculated the angle to a north vector using python, after which I round it to an int so I can group by it when combining lines. See https://knowledge.safe.com/questions/31810/azimuth-to-compass-directionbearing.html
It's not what I wanted and doesn't work for some cases where the difference in bearing is small but the rounding creates a difference.
Does anyone know a way to combine lines based on an attribute range?
Transformers:
Python code:
import fme
import fmeobjects
import math
def processFeature(feature):
    coords = feature.getAllCoordinates()
    if len(coords) < 2:
        return
    x1, y1 = coords[0]
    x2, y2 = coords[1]
    degBearing = math.degrees(math.atan2((x2 - x1),(y2 - y1)))
    feature.setAttribute("degBearing", degBearing)
Forum|alt.badge.img+54
  • Aug 13, 2018 3:09 PM UTC
Transformers:
Python code:
import fme
import fmeobjects
import math
    if len(coords) < 2:
        return
    x1, y1 = coords[0]
    x2, y2 = coords[1]
The method mentioned here might be a possibility
https://knowledge.safe.com/questions/47675/group-records-based-on-attribute-values.html
jdh
Forum|alt.badge.img+41
  • Aug 13, 2018 3:28 PM UTC
I've not done that, but I have generalized lines based on the deflection angle.
While it is possible to do so using regular transformers, it is several orders of magnitude faster to do so in python.
Essentially you would want to get the coordinates of the vertices, for each vertex calculate the deflection angle.
If it's greater than your maximum, then output that point.
Send the points and the original lines to a pointOnLineOverlayer
The deflection angle for any vertex i except the start and end vertices can be calculated by taking the the minimum of the absolute value of the difference of the segment angles and their complement
DeflectionAngle = min(abs(a2-a1),360-abs(a2-a1))
where
a2 = degrees(atan2(Yi+1-Yi, Xi+1-Xi))
a1 = degrees(atan2(Yi-Yi-1, Xi-Xi-1))
jdh
  • Aug 13, 2018 4:32 PM UTC
Consider the following:
import fme
import fmeobjects
import math
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        maxAngle = 10
        pts= feature.getAllCoordinates()
        #skip the first and last point
        for i in range(1,len(pts)-1):
            #get previous, current and next point
            p0 = pts[i-1]
            p1 = pts[i]
            p2 = pts[i+1]
            # get segment angles
            a1 = self.GetAngle(p0,p1)
            a2 = self.GetAngle(p1,p2)
            # calculate deflection between segments
            angle = min(abs(a2-a1),360-abs(a2-a1))
            #points that exceed tolerance
            if angle < maxAngle:
                feat = fmeobjects.FMEFeature(feature)
                p = fmeobjects.FMEPoint(p1[0],p1[1])
                feat.setGeometry(p)
                feat.setAttribute('DEFLECTION',angle)
                self.pyoutput(feat)
    def GetAngle(self,pt1, pt2):
        xDiff = pt2[0] - pt1[0]
        yDiff = pt2[1] - pt1[1]
        d = math.degrees(math.atan2(yDiff, xDiff))
        return d
    def close(self):
        pass
This should produce a point at every vertex where the deflection is greater than MaxAngle.
Suggestions for improvement would be to take MaxAngle from an attribute on the feature.
When using the pointOnLineOverlayer, you may want to use a group by if there is a possibility that your lines overlap (not at node).
  • Aug 14, 2018 12:23 AM UTC
import fme
import fmeobjects
import math
    def __init__(self):
        pass
        maxAngle = 10
            p0 = pts[i-1]
            p1 = pts[i]
            p2 = pts[i+1]
                feat.setGeometry(p)
                self.pyoutput(feat)
        return d
    def close(self):
        pass
Alternatively, the PolylineAnalyzer from FME Hub could also be used to calculate the deflection angle on each vertex, since the transformer would output vertex points containing "_angle_between_segments" (0-360 degrees) attribute to them, via the Vertex port.
deflection = @min(@Value(_angle_between_segments), 360 - @Value(_angle_between_segments))
I altered the solution from @jdh to create the desired effect of splitting the line at those points.
Note that it can behave strangely when you have multilines or other aggregates.
import fme
import fmeobjects
import math
    def __init__(self):
        pass
        maxAngle = 10
        prev_i = 0
            p0 = pts[i-1]
            p1 = pts[i]
            p2 = pts[i+1]
            a1 = self.get_angle(p0,p1)
            a2 = self.get_angle(p1,p2)
            #If angle exceeds maximum, output line so far
            if angle > maxAngle:
                self.output_line(feature, pts[prev_i:i+1])  # Make line from 1st coordinate up to and including i
                prev_i = i
        # Output remainder of line if a cut wasn't required
        if prev_i < len(pts)-1:
            self.output_line(feature, pts[prev_i:len(pts)])
    def output_line(self, feature, points):
        line = fmeobjects.FMELine(points)
        feat.setGeometry(line)
        self.pyoutput(feat)
    def get_angle(self,pt1, pt2):
        return d
    def close(self):
        pass
