Splitting coordinates into separate attributes
  • Jul 29, 2016 1:46 PM UTC
  • 202 views
Hi, would you please help me to have these coordinates separately with their own attribute? Thanks in advance. photo is attached
Best answer by ebygomm
If you have FME 2016 you can make use of the new capabilities of the stringsearcher to find all coordinate matches within the string
Then use an attribute creator to rename the list elements
Forum|alt.badge.img+54
  • Jul 29, 2016 1:57 PM UTC
erik_jan
Forum|alt.badge.img+26
  • Jul 29, 2016 5:23 PM UTC
If you do not have the latest version (2016.1) I would do the following:
Use the StringReplacer to get rid of "SRID=3607; POINT ("
Use a second StringReplacer to get rid of ")"
Use the AttributeSplitter (delimiter " " ) to split the coordinates.
And copy _list{0} to X, _list{1} to Y and _list{2} to Z.
  • Aug 8, 2016 7:41 AM UTC
Thanks for replying. I could go forward somehow with erik_jan advises forward. But got the last result came through Geometryreplacer.
  • Aug 8, 2016 7:45 AM UTC
Thanks for replying. Solving my problem through this way is hard for me to find correct parameters for "contains Regular Expression". But I have learned something new.
