Thanks
Pat
Thanks
Pat
Best answer by dai
I think the Points and Parcels both have the field Lat and Long what cause the field can not be populated. If you use the SpatialRelator ,the relate information will hold in a new list. I advise you to read the description of this transformer.you will get it. Or you can use the AttributeRemover to remove the field before using the SpatialRelator
No account yet? Create an account
