Spatial query with SQLExecutor
  • August 2, 2017
  • 10 replies
  • 130 views
I am trying to make a spatial query with SQLExecutor and having some issues. My filter is some point buffer features in a ESRI geodatabase and the feature points I want to filter are in an Oracle database. I am extracting the geometry and using SDO_RELATE as shown bellow. Using FME 2016.
My SQL query:
select * from gds.emb a
where a.DATAHORA >=to_date('01/01/2017 00:00:00', 'DD/MM/YYYY HH24:MI:SS')
and a.DATAHORA <to_date('01/02/2017 00:00:00', 'DD/MM/YYYY HH24:MI:SS')
and sdo_RELATE(a.GEOM,@Value(_geometry),'mask=anyinteract')='TRUE'
Best answer by erik_jan
Do you need to use the SQLExecutor?
I would use a reader for the ESRI feature and feed that to a FeatureReader transformer, reading the Oracle table and defining the spatial filter in the FeatureReader.
That is a lot easier.
  • August 2, 2017
erik_jan
Forum|alt.badge.img+26
  • August 2, 2017
fmelizard
Forum|alt.badge.img+22
  • August 2, 2017
Hi @patiaserica, would you be able to elaborate on the issues you're experiencing? Can you share any of the error messages?
  • August 3, 2017
I suspect it's the contents of the "_geometry" attribute that's not recognised by Oracle, what is the geometry encoding type used in the GeometryExtractor? If you use OGC Well Known Text, you could try:
and sdo_RELATE(a.GEOM,SDO_UTIL.FROM_WKTGEOMETRY('@Value(_geometry)'),'mask=anyinteract')='TRUE'
Notice the use of FROM_WKTGEOMETRY() to parse the Well Known Text-string into an Oracle spatial object.
  • August 4, 2017
Yes, I am using OGC WKT and already tried that one, but having this kind of error:
ORA-06512: em "MDSYS.MD", line 1723
ORA-06512: em "MDSYS.MDERR", line 17
ORA-06512: em "MDSYS.SDO_CS", line 3019
ORA-06512: em "MDSYS.SDO_3GL", line 205'
  • August 4, 2017
Maybe the problem is lack of spatial index?
  • August 4, 2017
Not sure, but that ORA-message is purely Oracle not not directly related to FME. Try executing the same query in Toad or SQLDeveloper and see if you get more information.
  • August 4, 2017
Worked perfectly!
gio
Forum|alt.badge.img+15
  • August 7, 2017
It is possible to do that.
You have to built the SDO string. I made a workbench to do that (after quite some fiddling). Explanation on ORACLE site is used to create it.
(it works as long as the geometry fits in a varchar as I pass it trough an fme attribute, after which you need to go for a PLSQL which I have not managed to do yet)
The WKT/WKB I tried as well, but you cant pass the SRID with the version fme uses. That is where oracle yields an error. You need updated wkt aka WKT2 for that.
To pass the srid you need
gio
  • August 8, 2017
creating the sdo geometry string and executing the spatial query using a sql executor is faster then using a feature reader.
