Some source data has not been used
  • April 11, 2017
  • 36 views
Hello,
I want to aggregate shapes from several subdirectories that have the same path and name structure. So "SourceDadtaset_SHAPE" =
N: \\ service \\ group \\ thematic \\ ** \\ shape \\ unites _ * _ 2.shp.
The script reads all shapes correctly, says the transaction was successful but displays "Some source data has not been used. This can happen if the dataset is changed or if a feature type is renamed or Deleted. "
However, it is not the case
Do you have an idea ?
Thank you
  • April 11, 2017
There's a pretty good explanation to that message here:
https://blog.safe.com/2011/05/fmeevangelist80/
  • April 11, 2017
Hi @40_eme, most likely the reader feature type has been set as an individual feature type (feature type name = a file name). Firstly check if the feature type is set as a Merged Feature type (feature type name = <All>).
