Snipper Transformer - why won't it always snip from both ends of a polyline?
  • Feb 7, 2023 9:56 AM UTC
  • 209 views
stu_home
I have a rail network, featuring multiple polylines. I need to snip 50m from the ends of each line.
Using the Snipper transformer, I use the Distance (Value) mode. The Starting location is 50, the Ending Location is the length of the line -100 (accounting for the 50 already removed at the Starting Location... maybe?!).
SnipperThe results are mixed: A dead straight line has 50m removed from each end, this is what I want.
Any other shape of line only removes the starting 50m, but NOT the end, as shown by the red "X" below. The blue lines indicate the Remnants.Snipper resultsWhat am I doing wrong? Can anyone help please?
Best answer by dustin
You will need to use @Length() where you now have @Value(SHAPE_length). So it would be @Length()-50 for the ending location.
dustin
Forum|alt.badge.img+36
  • Feb 7, 2023 3:09 PM UTC
stu_home
  • Feb 7, 2023 3:16 PM UTC
Oh I seeeeeee! Yes that works, thank you. Take a bow.
Forum|alt.badge.img+54
  • Feb 7, 2023 3:19 PM UTC
You should only need to specify 50 not 100, but either way you should see 2 remnants for each line snipped.
Are there any warnings in the log? Along the lines of
@Snip (or FMELine::snip) was given a range of (20,120), which is out of bounds for a line length of 100. Snapping params to closest valid value.
Are any of the lines doubling back on themselves?
stu_home
  • Feb 7, 2023 3:34 PM UTC
Thank you. @dustin​  answered it just now. I was using the wrong syntax. Once I'd used @length rather than @Value(Shape_Length) it worked a treat. And yes, I use 50 and -50 now.
