Snipper rejects features because of INVALID_GEOMETRY_TYPE
  • March 14, 2017
  • 5 replies
  • 103 views
I try to find the midpoint of a line using the Snipper transformer, but some of my features are rejected. The fme_rejection_code is INVALID_GEOMETRY_TYPE. I think it is because of the IFMEMultiCurve. How can I solve this?
Willy
  • March 14, 2017
Try using a GeometryRefiner before the Snipper and see if that helps.
  • March 14, 2017
@david_r: Adding the GeometryRefiner makes no difference.
  • March 14, 2017
Can you save a single such feature in an FFS file and post it here for testing? You can either use the FFS writer or the Recorder transformer for this.
  • March 14, 2017
Hi @willyb, if the entire shape of the MultiCurve geometry is a single polyline, you can decompose the MutiCurve into individual Line parts with the Deaggregator and then combine the parts into a single Line geometry with the LineJoiner.
Note: The LineJoiner has been renamed to LineCombiner in FME 2017.
gio
Forum|alt.badge.img+15
  • March 14, 2017
try geometryextractor and then replacer.
