single quote in name used as parameter - SQL Executor
  • December 5, 2019
  • 382 views
Is there a simple way to wrap a single quote mark in a string for the SQL Executor?
Occasionally we will have a name that contains a single quote i.e St Paul's and these are being passed in as parameters into a executor for a Postgres database.
thanks
Forum|alt.badge.img+50
You can escape the ' by adding the escape character, a ', in front of it.
SELECT * FROM "public"."Plaats" WHERE "naamNL" = '''s-Hertogenbosch'
Selects the value 's-Hertogenbosch
  • December 5, 2019
It depends on the underlying SQL server.
In Oracle you can use the "q" mechanism to specify an alternative quote delimiter, e.g.
select q'#Oracle's quote operator#' from dual;
In SQL Server it's possible to play around with these settings:
 SET QUOTED_IDENTIFIER ON/OFF
But I find it slightly hacky, for lack of a better word. You may be better off looking into the solution suggested by @redgeographics.
In Postgresql there's dollar quoting which I find pretty neat, e.g.
SELECT $$hello's the name of the game$$
Just read @david_r's answer, prompting me to point out I'm using PostGIS
erik_jan
Forum|alt.badge.img+18
  • December 5, 2019
Another simple way of doing this (I used Oracle) is replacing the single ' by two single quotes '', using a StringReplacer:
