Simple way to convert pointcloudxyz from a series of points to a polygon
  • Nov 2, 2020 2:35 PM UTC
  • 11 replies
  • 415 views
Hellow. I just want to take a simple pointcloudxyz and transform it into a polygon. it will be 2D so the z value will always be zero. Has anyone got a simple example of tutorial I can follow?
fme-phile
  • Nov 2, 2020 4:37 PM UTC
​@kowfoz1​
I have uploaded a simple workspace that may help.
You simply add the Point Cloud dataset; filter the buildings using the 'PointCloudSplitter' transformer if that is the layer you require, in this case classification = 6; Convert the point cloud to points using the 'PointCloudCoercer' transformer; Buffer the points so that the points overlap the other point features. in this case I buffered the points creating squares; and lastly, I smoothed the polygons using the 'Generalizer' transformer.
  • Nov 2, 2020 5:37 PM UTC
Thanks. WHat is the difference between HullReplacer and HullAccumulator exactly?
  • The HullReplacer creates a hull (convex or Concave) for each individual feature.
    • 5 lines/points = 5 polygons
  • The HullAccumulator creates a hull (convex or Concave) for each feature set.
    • 5 lines/points = 1 polygon
    • Attributes can be gathered into a list
You may need to use the accumulator if you deaggregated the cloud into individual points. It should already be a single aggregate feature so you can use the HullReplacer.
  • Nov 3, 2020 10:08 AM UTC
Thanks.
So would I be right in saying the bufferer actually gives the more accurate outline? As I actually want the more exact outline rather than a smoothed outline? See image attached
Captureat the moment I use Hullreplacer which actually gives too smooth a result
CaptureCan you help?
I see what you want to do. Buffers work but it looks terrible so you have to clean them up to look smoother. The attached workbench creates a randomized set of points to demo how this works. You will need to adjust the buffer sizes to match your units.
Workbench - Attached .fmwt
workbenchPoints with a buffer end up with ragged edges
bufferedpoints
Stroking the arcs of the hulls and buffering creates a cleaner outline
smoothedbuffers
  • Nov 3, 2020 12:28 PM UTC
bufferedpoints
smoothedbuffers
That is a great help. So now I have the image below:
CaptureThe buffer lines are quite thick though? How do I make them more like just lines connecting the dots of the original point cloud? Image below:
Capture
Capture
Adjust the negative buffer amount on the last Bufferer until you get the desired result. For example, if you change the example to a -2.4 it will almost be on the nodes.
Play around with changing all three of the bufferers to get a better idea of what it's doing. There's going to be a combination between those three that should be very close to what you want.
  • Nov 3, 2020 2:07 PM UTC
Capture
when you say negative buffer..... Which element below?
Capture
  • Nov 3, 2020 2:11 PM UTC
Capture
I tried -0.08 instead of 0.08 but then there is view displayed?
Capture
Buffer Distance can be positive or negative. A positive buffer will buffer outward and a negative will buffer inward.
In the example workbench, only 1 buffer should be negative. Marked below.
Buffer
There are 3 bufferers in the example process I sent.
  1. Bufferer = Initial buffer of the points to create overlapping polygons for dissolve (positive)
  2. Bufferer_3 = Creates the rounded edges from the hulls (positive)
  3. Bufferer_2 = Shrinks the polygon back down to the original size (change this one to negative)
Bufferer_2 can't be less than the sum of Bufferer + Bufferer_3 or the polygon will disappear because you buffered it out of existence.
So, if I have;
Bufferer = .6
Bufferer_3 = 2
Bufferer_2 = can be any value up to -2.6 without losing any data. If you go beyond 2.6, it may or may not buffer polygons out of existence depending on how many polygons were dissolved together.
