Simple Join failing
  • Oct 9, 2017 6:27 PM UTC
  • 5 replies
  • 64 views
Hi folks,
I got the attached error, very basic process, I'm joining a table loaded from a CSV with another CSV. It should be easy and my transformers are correct.
https://imgur.com/P3jkoQM
danilo_fme
Forum|alt.badge.img+58
  • Oct 9, 2017 6:45 PM UTC
Hi @osarhan,
Are you try to merger between two CSV files?
If yes, try with the transformer FeatureMerger.
Thanks,
Danilo
  • Oct 10, 2017 8:12 AM UTC
Hi @osarhan,
Thanks,
Danilo
I was originally doing this, but both files are extremely big so it it hits memory constraints :(
danilo_fme
  • Oct 10, 2017 12:32 PM UTC
Perfect. Could you share the print inside your transformer Paramenters Joiner and share it?
Thanks,
Danilo
  • Oct 10, 2017 12:46 PM UTC
I don't think the Joiner is particularly well suited to join two huge CSV files, personally.
I would use the FeatureMerger, but it's important to make sure that you use two separate readers, one for the supplier CSV and one for the requestor CSV.
In the Navigator, make sure the suppliers CSV comes at the very top, this means that dataset will be read before the requestors.
You can then tell the FeatureMerger that the suppliers come first, which will "unblock" then transformer making it a lot more efficient memory-wise.
Another alternative could be to use the InlineQuerier, but it's slightly more complicated. Let us know if the "non-blocking" FeatureMerger doesn't work, and we'll help you if needed.
