Simple calculation and write in subsequent feature
  • Jul 8, 2019 2:00 PM UTC
  • 7 replies
  • 118 views
connecter
Forum|alt.badge.img+10
I have a little calculation problem:
I want to @sub(A1,B1) and write the result (72) at A2. Next step A2-B2 (72-18)--> result (54) at A3... and so on. The dataset must be flexible, because the input is not only 3 rows long.
Thank you for your help!
Best answer by oscard
Sorry, I think I was explaining myself very badly.
I have attached a workspace with what I think is the result you want.
xlsxr2none.fmw
oscard
Forum|alt.badge.img+23
  • Jul 8, 2019 2:09 PM UTC
Add an AttributeManager to your workspace after the Reader.
In that transformer, enable the adjacent features. Number of prior features = 1
Calculate the A value in that AttributeManager as: @sub(features[-1].A, features[-1].B)
I think that should do the trick.
Forum|alt.badge.img+63
In the AttributeManager you can use the adjacent features option to access attributes from previous features, as long as everthing remains in that order you can do it.
Check out Excercise 3 of the Advanced Attribute Handling part of the 2018 Desktop Advanced course, it does something very close to what you're trying to do here.
connecter
  • Jul 9, 2019 6:05 AM UTC
Thank you for your response and help. The exercise is a little bit different and when I try it, I don´t get the right result:
In the exercise the @sub from month to month is taken and is writen in a new attribute.
I tested a little bit around with the "Substitue Missing, Null and Empty by" option:
The result isn´t in cell A2 (all results are feature[-1]), but it is caluclate right:
oscard
  • Jul 9, 2019 1:17 PM UTC
You need to ignore the first row with a conditional value.
Before the AttributeManager, add a Counter. Then, in the AttributeManager for the A value, you need to put a Conditional Value. Something like this:
If _counter != 0 Then @sub(features[-1].A, features[-1].B)
Else (do nothing)
Hope that helps.
oscard
  • Jul 9, 2019 1:26 PM UTC
xlsxr2none.fmw
gio
Forum|alt.badge.img+15
  • Jul 9, 2019 4:06 PM UTC
@oscard
If it is to excell, you can also write the expression (in english and quoted) to excell itself.
So in A2 "=A1+B1"
A3 "=A2+B2"
etc.
Use stringconcatenator.
Or you can expose xls_row_id then explode and do the expression.
Or of course, as it is only one row down, you canuse adjacent features. (But what if it is not just 1 row down?) You than need to use stringconcatenation anyway.
connecter
  • Jul 10, 2019 5:12 AM UTC
@oscard thanks! It works.
