ShortestPathFinder processing time
  • Oct 15, 2024 10:32 AM UTC
  • 155 views
emerson_styles
Forum|alt.badge.img+4
I have a workspace that is calculating the shortest path across a network for a dataset of start and end points (joined as lines). The length of time it is taking to process the data through the ShortestPathFinder transformer is a lot and it sits as follows for hours on end:
Is there a way to speed this up at all? I know I’m trying to process a large amount of data which could be the primary reason but I am curious if there are ways to perfect this process to enable it to complete much faster.
  • Oct 15, 2024 3:11 PM UTC
First rule of high-performance FME: Turn OFF feature caching :-)
https://support.safe.com/hc/en-us/articles/25407655250573-Feature-Caching-and-Performance
Secondly, make sure to only keep the relevant attributes before doing any processing. Remove any unecessary attributes from the readers e.g. using AttributeKeepers.
Forum|alt.badge.img+54
  • Oct 15, 2024 4:53 PM UTC
If you want to keep some featurecaching but reduce the overhead, anything you collapse in a bookmark is not cached so can be useful for some cases.
Another option is to split your From-To Lines into chunks and then set up a workspace runner to run a child workspace that does the shortest path calculation with 7 concurrent processes. You probably want to store your network somewhere so it is used in each process rather than the doing the PointOnLineOverlayer processing each time
mark2atsafe
Forum|alt.badge.img+59
What are your parameters in the ShortestPathFinder? They can make a huge difference to the time taken, especially if you have the Advanced parameters such as Finish Conditions turned on.
If you can file a support ticket with us - and include your data - we’d be very happy to take a look at why the performance is so slow.
