Setting temp location for FME WB
  • May 5, 2020 11:59 AM UTC
  • 116 views
Hi all,
I was looking at this arcticle:
https://knowledge.safe.com/articles/176/fme-temp-environment-variable.html
I have created FME_TEMP system variable to point to an drive with a lot of space (D drive)
I have some big WBs which create a lot of temp files, but these still go into c:\\user\\...\\temp folder and sometimes space on C drive will run out and WB will fail.
What is the problem here and how can I tell FME desktop to write temp files to D drive? Do I need to create the FME_TEMP per user and not per system? Something else?
  • May 5, 2020 12:12 PM UTC
Did you try rebooting the PC after setting FME_TEMP?
Also make sure that FME_TEMP points to an existing folder.
erik_jan
Forum|alt.badge.img+26
  • May 5, 2020 2:23 PM UTC
Another option would be running FME using a batch file.
In the top of the batch file, I tend to have these lines:
SET TEMP=d:\\temp
SET FME_TEMP=d:\\temp
This will set the TEMP location for the current session (to d:\\temp) only.
Hope this helps.
