Setting a list of lists as a _list attribute in PythonCaller?
  • Oct 30, 2023 4:21 PM UTC
  • 114 views
fneal
Forum|alt.badge.img+4
I have a list of lists resembling this structure:
sublists = [[1,2,3],[4,5,6],[7,8,9]]
When I try to set this "list of lists" into a list attribute I get the following:
code -
feature.setAttribute('chunkList{}', sublists)
error -
Python Exception <TypeError>: Could not convert attribute value to a supported attribute type.
Traceback (most recent call last):
 File "<string>", line 95, in input
TypeError: Could not convert attribute value to a supported attribute type.
Error encountered while calling method `input'
PythonCaller_Get_chunkList (PythonFactory): PythonFactory failed to process feature
  1. The goal is to have a list of 1000 unique IDs or less to feed into a reader
  2. I do not know how many lists there will be ahead of time so I need to dynamically break out the lists into individual lists of 1000 elements later in the workflow which is why I want 1 list of lists to start with.
Best answer by david_r
Try something like
for n, item in enumerate(sublists):
    feature.setAttribute('chunkList{%s}.sublist{}' % n, item)
Result:
imageYou can then do a ListExploder on chunkList, if you need to have one feature per sublist.
  • Oct 30, 2023 4:35 PM UTC
Try something like
Result:
fneal
  • Oct 30, 2023 6:24 PM UTC
Thanks for the quick response @david_r​, that did the trick! I did want each feature to have its own sub-list which I exposed and then concatenated, giving me the queries I will need for each set of records to fetch from a reader.
Sublists
