Set attribute JSON with Python
  • Dec 17, 2015 1:28 PM UTC
  • 5 replies
  • 286 views
danilo_fme
Forum|alt.badge.img+58
Hello all,
I have a Workspace that makes the reverse geocoding using PythonCaller.
import fme
import fmeobjects
import json ,urllib2 #
def processFeature(feature):
att = urllib2.urlopen('http://maps.googleapis.com/maps/api/geocode/json?latlng=-23.2186725,-45.9056706')
data = json.load(att)
print "o json é ", data
When i run my workspace i see the results on the log file because i put the Print:
How can i get this result with a new attribute?
Thanks in Advance,
Danilo de Lima
Best answer by david_r
Try something like
feature.setAttribute('myJSON', json.dumps(data))
You can then use the regular FME JSON transformers to work on the new attribute "myJSON".
David
  • Dec 17, 2015 1:37 PM UTC
Try something like
David
danilo_fme
  • Dec 17, 2015 1:43 PM UTC
hello @david_r thanks your help. Its works!!!
Amazing. :) The secrets is the json.dumps, other?
Thanks in Advance,
Danilo de Lima
danilo_fme
  • Dec 17, 2015 2:01 PM UTC
Thanks in Advance,
Danilo de Lima
@david_r Thanks the explanation and the link.
  • Jun 6, 2018 7:32 AM UTC
Thanks in Advance,
Danilo de Lima
Look in the Python json module documentation. Basically:
.dumps() transforms a string into a Python dictionary
.loads() transforms a Python dictionary into a string
gedgg
  • Mar 11, 2025 4:58 PM UTC
Try something like
David
Hi David,
in 2024.2 I have json that I dump into text as you suggested.
feature.setAttribute("output_result", json.dumps(results))
Then I have attribute exposed, but not sure why it keeps coming out as <missing> . Also not sure what data type to use since simple text option does not exist.
I am successfully printing data, just no luck outputting into attribute:
EDIT: my error was self.pyoutput(feature, output_tag="PYOUTPUT") placement. Moving it to the bottom of input function solved all the problems…. 🤓
