Separate a string into parts according to alpha or numeric characters used
tim_bkr
Participant
Forum|alt.badge.img+5
I have an identifier attribute which can take different forms.
All contain a number, like 985 or B985 or 985a
Some are preceded by a capital letter like B985
Some are followed by a smallcaps letter or the character "*" like 985b or 985*
I want
  • the capital letters at the beginning of the string to go into attribute PREFIX
  • the numeric to go into attribute NUMBER
  • the smallcaps letter or the * to go into attribute SUFFIX
I imagine using regex is the way. I have got the job partly done with a series of StringSearchers but I'd like to have advice from someone with experience.
Thanks in advance !
@tim_bkr​  You're probably on the right path with a regular expression in StringSearcher. Something like:
([a-zA-Z]{0,1})([0-9]+)([a-zA-Z\*]{0,1})
Go to regexr.com to learn how that expression works.
The trick is on the StringSearch under Advanced use the Subexpression Matches List Name:
dialogI've attached an example workspace (FME2021.0).
tim_bkr
Participant
  • Participant
  • May 17, 2021
Waw, brilliant !
Thanks a ton !
