Select by location - along a line
  • Mar 9, 2020 7:37 PM UTC
  • 260 views
lambertus
Forum|alt.badge.img+25
For my current task I have a road network (purple lines) and 2 datasets with points.
Dataset 1: green points
Dataset 2: red points
What I want to do now is to select points from dataset 2 which intersect or are close to dataset 1. See the attached figure for examples.
However, I want to limit my search for the test 'are close to' within a single line. The FME method/tool should not look at points which are postioned at parallel running lines. In the figure below I do not want to select the red point indicated as 'not intersecting'. There are green points closeby. However, they aren't postioned at the same line which should be the case to be considered as a closeby points.
I tried something with the NeighborFinder. This works fine. Only situtations like the one below I did not solve yet. Any suggestions?
Forum|alt.badge.img+54
  • Mar 9, 2020 8:04 PM UTC
Before your neighbour finder use a spatial relator or a point on line overlayer to transfer the road id to the points. Then use this attribute as a group by in your neighbour finder
lambertus
  • Mar 9, 2020 8:08 PM UTC
Thanks for your fast reply! I am going to implement your suggestion and check the outcome :)
lambertus
  • Mar 10, 2020 12:32 PM UTC
It is not working yet. I guess the road id used in the Group By parameter should be unique? That not the case yet in my road dataset..
  • Mar 10, 2020 12:38 PM UTC
You could just use a counter to assign an temporary id to the roads
