Schema reporting ListHistogrammer
  • Sep 2, 2013 8:38 PM UTC
  • 55 views
Hi All, i have a large number of ESRI SDE featureclasses and am looking to undertake data attribute cleaning. I choose what tables/attributes i am going to clean i need to create some reporting on each table
I am trying to loop thru all attributes in a table build a list of the values and frequencies then output these to xls as concatentated strings
ie Attribute1, Value1,3,Value 2,99,Value3 43 etc etc
ie User, John,3,Sally,43,Matthew,99,matt,1 etc etc
I have built lists and utilized the ListHIstogrammer but how to i take the values from the listHistogrammer and create a new List (or python dictonary) of the histogram value and count? ie Value1,Count99,Value2,Count 4 etc etc
Thanks for your help
Steve
  • Sep 3, 2013 2:14 AM UTC
Hi Steve,
I think the StatisticsCalculator transformer is suitable to this case rather than the ListHistogrammer.
For example, if you set the parameters of the StatisticsCalculator like this:
Attributes To Analyze: Attribute1 User
Histogram List Attribute: histogram
the output feature (SUMMARY) will have these list attributes. Attribute1.histogram{}.value
Attribute1.histogram{}.count
User.histogram{}.value
User.histogram{}.count
Then, you can get the value-count pairs of each attribute (Attribute1 and User) from these lists.
Finally, if you need to create concatenated string like "Attribute1, Value 1, 3, Value 2, 99, ...", a PythonCaller with this Python script (for example) would work.
import fmeobjects   class FeatureProcessor(object):     def __init__(self):         pass              def input(self, feature):         attrNames = ['Attribute1', 'User']         for attr in attrNames:             values = feature.getAttribute('%s.histogram{}.value' % attr)             counts = feature.getAttribute('%s.histogram{}.count' % attr)             s = attr             for (v, c) in zip(values, counts):                 s += ', Value %s, %s' % (v, c)             newFeature = feature.cloneAttributes()             newFeature.setAttribute('attr_value_count', s)             self.pyoutput(newFeature)              def close(self):         pass -----
Takashi
  • Sep 4, 2013 10:49 PM UTC
Many Thanks for your input Takashi,
yes this is perfect.
I appreciate your python code also. I know python but am not that good at intergrating it with FME yet !!
Thanks Again
Steve
