S3Connector connection error
  • Jul 10, 2023 12:44 PM UTC
  • 0 replies
  • 234 views
I am trying to use the S3Connector to upload/ download from an s3bucket.
Just to test this out i have setup a AWS web connection and i am trying to list all the files in the folder FMS/
image.pngI keep getting the following error:
S3Connector: There was an error connecting to Amazon S3: 'Failed to connect to proxy URL: . Confirm that your credentials and region settings are correct. Some regions are not publicly available - contact AWS for more information
I have played about with the proxy settings but im not entirely sure that is the issue as i have a python script that uses all the same credentials and proxy settings and that works okay.
Im on FME version 2022.0 and using s3 connector version 2.1.2
Any advice would be appreciated
